Guys, I have had an inquiry concerning the number and types of evap jobs being accomplished in repair shops today. If possible, please post remarks concerning the vehicles that exhibit the most evap failures, second, third, etc.
iceman2555
I've seen 3 Caravan/Town & Country evaps leak '97 up to 2000-- and two Dodge Ram pickups- both '97- no one wants to spend the bucks to fix-- and I don't care to do the dash pulls.............Late model GM's have been good for me- the older r-12 days they were really bad......
going along with gmtech on alot of dodge chrysler products! caravans (done a 2000 tuesday of this week) dodge full size 96 thru 01 or 02, 1993 thru 1998 Gran Cherokees (basically the same evap and box as dodge full size pickups of the same era) we have done about 4 or 5 1999 and newer gran cherokees this summer too!
From all the posts, Chrysler is king in this respect, followed by early GM, wouldn't have been a problem if they only used the kind of aluminum alloy they use in throwaway soda pop cans.
What's the typical labor cost for a front A/C evaporator replacement in a Chrysler minivan?
I'm in the midst of doing it myself and I'm trying to convince myself that all this work is really worth it. It took me about 6 hours to get the dash disassembled and get the evaporator replaced. I'm guessing it's going to take me a total of 10-12 hours by the time it's all done. I'm in the process of buttoning everything back up, and hoping I end up with less than a dozen "spare" screws by the time this job is complete.
In addition to the evaporator, I'm also replacing the expansion valve, accumulator/drier, and all the rubber gaskets I can get to under the hood. I'm also planning to drain and replace the PAG oil in the compressor. I've been wavering on the condenser, but currently not planning to replace it or the rear condenser or evaporator. Anything else that I should replace while I've got the system opened up, or any other gotchas I need to look out for?
Wade
If you are referring to a 96 and up chrysler, dodge etc mini van my mitchell gives a little over 10 hours labor including evac and recharge!
Fran,
MY 96 Chrysler LX had 3 evaps exchanged under warranty. I clamped a braided ground wire to the outlet pipe and the evap lasted for another 5 years until it sold.
Talked to Chrysler Engineers and they finally made running change to the Al alloy across the board.
Cordially,
Old IV guy
1991-1998 Mercedes S-Class (W140 Chassis) evaps... these have to win the prize as the WORST!!! Not only did these evaps fail often, and the evaporator was stupid expensive at over $600, it is a HORRIBLE job... one I'm never ever volunteering for again! Book rate is 28.0 hours, though most shops specializing in Mercedes can get it done in about 19-20 hours... two weekends for me and my buddy.
If one rolls into your shop, don't walk - run, very fast!
Joe
I agree with those who have mentioned the Chrysler minivan evaps. I don't do auto repair professionally, but I've heard story after story about evap replacements on '96 - '00 minivans. My vehicle had the repair done (in '04 I think) before I got it.
It is an extremely labor intensive job, requiring removal of the entire dashboard assembly including steering wheel. The evap is buried inside a HVAC unit under the dash; the entire HVAC unit has to come out too.
The TXV on my van has a ground strap, which should in theory ground the entire evap.
Seen a lot of Range Rovers here with leaking evaporators but Volvos (70 Series) are a popular car to leak too
Heard and seen too many things with the Chrysler minivans. The guy that does my A/C hates doing these. Saw one that the dash was totally taken out just to replace the evaporator. Got to love my old B-bodies where the evaporator is under the hood. 30 minutes and its out without ever touching the dash. People wonder why I dont keep the new cars for more than 4-5 years. The old B-bodies are different. The parts are easy to replace on those.
2008 Chevrolet Impala LS
1981 Pontiac Bonneville
2007 Sears Craftsman Lawn Tractor
1985 Chevrolet Caprice
1986 John Deere 165 lawn tractor
I hear alot of complaining about the evaps leaking in alot of these vehicles I personnally dont mind the dash on the chrysler minivans or jeeps the mercedes is another story but the volume is not there ! I have pulled the dash on 2 ford f series this week 97 f150 and a 98 expedition heater leaking in it, blend door on pickup I would just as soon do that as work under the hood any day maybe when I get 50 years old and my eye site goes I may not enjoy it, but now i still do !! send them to me!
I have a Chrysler minivan ('97).
Just a naive question.....I haven't had to deal with the evaporator replacement yet (knock on wood), but just curious what it is you hate about the job so much? Is it just monotonous (sp?), because I'd think if your billing for your time then who cares if it takes 10-12 hours, you're getting paid for that time, right?
I *can* see where you'd hate dealing with the customer side of things when you tell them that their van that's only worth about 3-4k is going to require $1500 (not sure if this the going rate or not) to replace the evap, and they go ballistic.
I think the biggest issue that makes this 9 hr. Chrysler mini van job a pain is when you have to dig that deep for a service item (that would be an A/C techs opinion, obviously not the manufacturers), then you will own every squeak, rattle, and dash light issue from that day on. Its not the hours, it's the pain.
What is so distasteful is not the repair.....but the customers who seem to think that they are being 'ripped off' when these astronomical charges are levied. Never mind that this ties a tech and a bay up for a day.....and of course, as HECAT states...once the first tool touches a fastener....we automatically become the owners of what ever befalls that vehicle after the repair......
Would much rather do the three compressor jobs.....the 6 or 7 brake jobs.....or other more profitable jobs than take on one of these. If mfg'ers would require...say...a year or two of apprentice service in a shop atmosphere.......prior to a design engineer ever touching a drawing board......ahhhh...think vehicle would be much more friendly to repair.....But during these day dreaming episodes....heck....seems that dream always turns to some other more...more....exotic dream....south sea island...warm trade wind breezes.....currents....clear water.....boat.....fishing......and of course.....the island does have its own large test tract.....so that all these high performance vehicles in the other part of the dream can be driven at very high rates of speed.......yeahhhhhh!!!
WAY BACK IN TIME, the first 2 Navy ships I served in were of the USS Knox (DE-1052) class. It was lore then, don't know if really true, that this class was designed by a lady as her Doctorate thesis in Marine Engineering. Good ships to steam, although a might wet forward, but a real B***H in the engineering plant to work on!! So it's not just cars that have this problem.
Dave
Hmm, speaking of evaporator replacements, mine's looking a bit corroded and coated round the fins. I've done my best to clean it but it tends to smell even on a rainy day.
Do you know anybody that make or repair evaporators? Only for interest at the moment, but I might need it repaired or replaced in the future, and with my car at over 20 years old, Volvo stopped making these kind of parts a long time ago. And because the Volvo 360 was never made for the USA market, aftermarket parts are hard to come by too
Edited: Sat October 20, 2007 at 12:02 PM by pettaw
I once replaced the evaporator in a 94 Jeep Grand Cherokee. Same as the minivans, it requires the entire dash to be removed. It took me about 30 hours in and out. However, afterwards I somehow managed to misplace the harness side connector to the blower module. I looked high and low w/o success and even hired a local AC shop to try. They called me later to come get the truck. I finally traced the wires through the wiring harness diagrams and found the wire had somehow been pushed behind the carpet in the foot well. This was after about a week or so of frustration. I convinced my daughter to get rid of this maintenance hog, and she agreed.
regards
See you down the ROW.
