Year: 1987
Make: Chevrolet
Model: Pickup
Engine Size: 350
Refrigerant Type: r134a
Ambient Temp: 95
Pressure Low: na
Pressure High: na
I have a couple of questions for you experienced AC guys. IâÂÂm restoring a 1987 Chevy full-sized pickup and IâÂÂm considering making some changes to the AC system. I need to replace the old tube and fin condenser anyway so IâÂÂm considering buying a new parallel flow unit for a 1995 Chevy truck and modifying the radiator support to make it fit in the 87. The units are approximately the same size, 16 inches by 27 inches, with the inlet and outlets on the same side. At this point I have the hood, finders, inter finders, bumper and grille off the truck so itâÂÂs not a big deal to pull the support off to make the modifications. My first questionâ¦can the 87 factory hoses be modified to connect to the 95 unit? Inlet on the 87 condenser is þ-16 male o-ring, outlet is 5/8-18 male o-ring, on the 95 unit both inlet and outlet are M20 x 1.5 male o-ring. Now the big questionâ¦. is it worth doing this? The 87 condenser is fairly large, 432 square inches, will it be efficient enough to cool the cab well with the truck idling and outside temp around 95 degrees using R134a?
I have an 85 Suburban, basically same system, excepting for the 7.4L V8. I did a full retrofit several years ago and am generally pleased with the results. At idle in hot weather, the vent temperature does rise.
Personally, I would not be swapping anything from OEM unless you could have documented 15% or more heat exchange. My advice is to buy an aftermarket direct fit condenser for this vehicle, saving hours off the job and change everything, including lines, drier, orifice tube and pressure switch.
Grove Automotive Group, Inc.
An Alabama Corporation
