Just wondering. I have an old set of r12 gauges that work really well. I already have conversion fittings for the 134a High & low pressure hoses. Are there any fittings for the center hose? One that would convert the hose to fit to 134a referigerate cans?
Thanks!
Sure is, just e-mail the guys at ackits.com and tell them what you need. They have the adaptors to change your gauge set over to R134a if you want..Hope this helps..
Really the only center line adapter is this.. This will allow you to attach your yellow hose to a 30lbs R134a cylinder. If you use the small cans just use this as it has both the R12 & R134a hook-up.
