I am having a very difficult time removing any of the connections on my 2001 dodge ram. There is a C clip that i slid off with no problems but the pipe/lines are stuck together.
Do I need a special tool to remove them?
Spring lock Tool Set
is there anyone that carrys them locally? im located in dallas,tx
im right in the middle of the job
Edited: Fri May 09, 2008 at 11:18 PM by EverydayDiesel
Someone locally should have them. Pretty popular tool.
Autozone, Pep Boys, Kragen, Napa , Carquest will have them.
If you are creative you can make the tool out of a plastic oil bottle cap or safety seal. You simply cut a round strip of the rim and trim it to the circumference of the fitting. You slip it under the spring and there you go!
