Year: 2003
Make: GMC
Model: Envoy
Engine Size: 4.2L
Refrigerant Type: R-134A
This guy works with me- was in China when his wife throws the belt off their 2003 Envoy-- compressor was seized- slipping the clutch- His father puts on a new belt- unplugs the compressor- waits on my buddy to come home-- Sight unseen, I advise him to buy a used compressor (new Sanden Scrolls are $629- remans are $239) - got one from a salvage yard off a 2007- stepping up 4 yrs- clean as whistle-- put it on last night (3hrs labor) -tight quarters to work through- have to pull alternator and a few other obstacles- the old Sanden scroll had the fixed scroll walls broken out- a clean failure- no debris to speak of- makes me wonder is this common for the Sanden scrolls to fail in this manner? or is there an issue with liquid refrigerant slugging- the compressor did seize in cool weather- rainy- when owner turned on defrost- so to bust apart that fixed scroll walls- it took a pretty good hit-- Has anyone else had this type of failure???
The good news is he bought the pump with a lifetime warranty (extra $20) from a salvage yard for $125 plus $15 to UPS to his house next day delivery- and I put it on for only 3 hrs labor-- so he gets the entire job for about $240. He'll be buying me coffee for the next month.....
Tim, got your ears on?
You can get a new Sanden scroll TRSA12 for a lot less.
Cordially,
Old IV/Frigette guy
You mean this one.
20-03450
I keep saying all the time we have so much more then what is listed and I am just an email away if there is a question.
Hey GM Tech, did it look something like this one?? If so we get a few every summer from Honda Civics, to Dodge vans... So in my opinion, yes it's a common failure on scrolls to blow the sides out..
It wasn't as bad as your photo- the fixed scroll inside was busted up pretty bad- but no external casting wall damage- I can't help but think liquid slugging is involved somehow--scroll should wear evenly and to severely break out walls would take an extreme force- such as is generated by trying to pump liquid refrigerant-- so I'll keep studying this failure mode- and welcome anymore evidence......
On the Honda civic the compressor is mounted low, on Dodge vans on top like an HT6, I get this failure from both. Usually it's a ball bearing came loose and got caught in there blowing the side out, or some other contamination. Most aren't that bad, and even this one looked complete until I got it out and the pieces fell away...
