Year: 1991
Make: ford
Model: taurus
Ambient Temp: 85
Pressure Low: vacuum
Pressure High: 210
recovered 134a was overcharged had about 50 oz in it .Added dye pulled a vacuum then charged by weight 32 oz 134a system would not kick on jumped low pressure switch. At idle sysem pressures were low side in vacuum high side 200 psi. would changing dryer and oriface tube be a waste or would you suggest flushing everything adding dryer and ot ,oil, vacuum then charge.thanks for any replies!
The 91 used the FX15 compressor, which is now thru your system. Best to do a firewall foward on that one..Once an O tube is clogged enough to pull the low side into vacuum, it's beyond flushing, with the black death FX15 anyway... Do pull the O tube though..Gonna look sort of like this one..
