Year: 2002
Make: JAGUAR
Model: X-TYPE 2.5 SEDAN
Engine Size: 2.5L V-6
Refrigerant Type: R134A
2002 X-type 2.5 help! 74K miles
A/C trouble! My A/C isn't working properly! It blows Ice cold at steady speeds above 40MPH I mean after driving on the freeway for awhile it can freeze you out.......Below that or stopped or in traffic ! It blows cold air!..... Then warm air!.... Cold air .....Then warm air!..... I never get it cool in my car driving around town! Its always warm in my car driving around town! I am forced to leave the setting at LO with the fan sitting at High all the time! It also leaves a more then normal puddle of water ! I suppose! maybe a leek ?? Even after starting in the morning ! Is this ok ???? Any help guys i would really appreciate it! I hope I can solve this!
I know nothing about automotive A/C's or any A/C for that matter! .... Thanks again ! Hope I can obtain an answer....
Ryan.....
Water is good, means it's removing humidity from the air. Can't have too much of that.
Check that all the fans under the hood are running when you turn the A/C on sitting still. Sounds like the car needs to be moving to force air thru the condenser, because the fans aren't doing it.
