Year: 1998
Make: Ford
Model: Expedition
Engine Size: 4.6
Refrigerant Type: R134
Ambient Temp: 100
Could someone give me the normal pressures for a '98 Expedition .? I was test driving it to check an ignition problem and vent temps never got very cold. Seemed to be in the 50's. Are there any common failure points for this system? It has 140k miles. Thanks
The only way to test it properly is to evac/recharge to system specs. Not sure, but they use an engine driven fan, with electric? if so, I would suspect the fan clutch..Pressures can range around 2.2 to 2.5 times ambient on the high side, but that is a guide for checking properly charged vehicles and retrofits.. When you have a large vehicle, you really can't go by pressures, you can overcharge it quite a bit before high rises to much,.,.Check air flow over the condenser, clean the condenser and area between it and the radiator, and the best bet is to recover/recharge, then check for any problems..
