Year: 2003
Make: Toyota
Model: sienna
Engine Size: 3.3
Refrigerant Type: r134
I have a leak in a connection in the low side line that goes to the rear evaporator. I'm trying to find out what kind of tool I need to take this connection apart so I can replace the oring. Also, if I add a little oil what kind should I add?
Can you post an image of the connection?
Can you post a picture of the connector?
I'll go get a picture.
May need a little help posting it.
Just let me know and I can walk you through it.
Simple explanation.
Save image to a file on your computer and remember where it is located. When logged in here click the upload image icon in the upper right menu. Click the browse bottom and go to the image stored on your computer. Select and upload it. After it is upload a link with be listed, copy it. Start a new post and paste the link or click the image icon and paste it there.
Here it is.
http://www.autoacforum.com/forumimages/PICT0059.JPG
Edited: Wed July 09, 2008 at 1:02 PM by Automotive Air Conditioning Information Moderator
Toyota spring lock- Special Toyota spring lock tool needed.
Thanks!
I'm going to try and find one locally so I can get my buddies van back to him. If not I'll order from you guys.
Can you tell me what kind of oil?
Wow what Ford is saying about them being better than Toyota must be true. Toyota got inspired to copy one of Ford's worst features.
I don't understand that connection either - it appears that there is a plastic housing that you need the special tool to remove. Once removed, does the joint come apart, or do you also have to use the (standard) ford springlock tool to separate the joint?
I'm assuming the connection of interest is the one covered in green slime ;-)
Can't find one locally.
Didn't locate one at Ackits either.
The last one of those I had to deal with got cut out, and replaced with a Swagelok.
One of Tim's inline filter housings would probably do the same job as the Swagelok.
B.
According to the NAPA manual, all Toyota factory R-134a systems use PAG 46.
The tool looks like a screwdriver with two pins in the end. Some have a curved shaft to aid access. I made one by grinding the center out of a seldom used stubby flat bladed scewdriver. It looks like a two-prong fork.
Rotate the clip until you can see two parallel slots. They will be perpendicular to the tubing axis. Press the two pins into the slots and the clip releases. Then just pull the tubes apart.
Ken Kopsky
Custom Car Works
