Are the GM compressor suction/discharge o-rings in the kit sold by Arizona Mobile Air oval or round?
GM changed the design in 1988 from round to oval. GM says the oval ring is backward compatible with o-ring compressors made 1966 - 1993 and no longer sells round ones.
4-Seasons sell both types and claim the round one is âÂÂstandardâÂÂ.
I use all oval when needed- but anymore mostly see sealing washers- since the change to sealing washers in the early 90's-- I don't believe there are any compressor built new with o-rings grooves- since there is a sealing washer conversion kit-- any o-ring compressors would be older ones that either are still functioning- or that have been rebuilt- All OEM pumps are sealing washers- a much better seal.
No doubt the sealing washer is a better way to go but they canâÂÂt be used on an o-ring style compressor. There are lots of those still around and people are still converting them (even A6's) to R134a.
The oval ring looks like it doesnâÂÂt fit right cause it leaves a gap around the groove but thatâÂÂs âÂÂnormal and expectedâ according to ACDelco.
Anyhow, I got the answer to my original question and the suction/discharge port o-rings in the GM kit sold by AMA are oval.
