Year: 1995
Make: GMC
Model: Suburban
Engine Size: 5.7
Ambient Temp: 101
Hello...new at this. I'm wanting to buy a valve core replacement kit. Is there a guide to knowing what size/type you need? Are the old valves high/low sides marked,colored? This will be mainly on GM 95-05's if that is any help. Thanks in advance, john
This should take care of your valve core needs.
Assortment of Valve Cores.
Valve Core R & R Tool
On many models in the year span you mention, the "high" side service port will need to be changed, not vale core. You can the guys at ackits.com for availabilty of the high side service ports.. Hope this helps..
Just did one last night-- the guy before had put silicon sealer in the cap-- what a mess!!!
Ha, the kind you can change, some have to replace the entire hose because of a leaking tiny piece of neoprene rubber.
