Year: 1993
Make: Chevy
Model: S10 Blazer
Engine Size: 4.3
Refrigerant Type: R134 Conv
Ambient Temp: na
Pressure Low: na
Pressure High: na
How do you adjust the AC clutch ? I replaced the compressor w/clutch 3 months ago. All was well until yesterday, when it started blowing hot air, When the clutch did engage air was cold. Upon investigation today, clutch is dragging slightly when not engaged. Did the clutch bearing go bad. Clutch face shows some signs of heat. I guess I'll need to replace the clutch as it may be toast Help!!! THANKS!!! -
JOHN
Borrow the clutch puller from Autozone- back clutch off to .020" and be happy-- your bearing is not bad if noise is only heard with a/c off..
The clutch was definately slipping when it tried to engage , so that means the clearance must be made tighter. Yesterday Phoenix temps went past 112, I noticed the poor cooling while stopped at lights, but it didn't recover. When it did get a good "grip" the ac blew cold air, but the clutch shows signs of heating/ slippage. Did the extra temperature stress drive the system pressures higher causing the clutch to slip by being harder to turn? It didn't drag before and did engage firmly, but now with the dragging , I suspect further bearing damage caused by heat due to slipping. I guess where I'm going is that if I replace the clutch, I need to know how to adjust it properly.
You should get the pressures along with the ambient temp. Make sure your fan clutch is operating properly, was anything added to the system when you changed the compressor like sealers?? but if you just want to change the clutch check this thread on changing front seals, it shows the tools needed to remove the clutch, snap ring holds pulley on..Hope this helps..
PS: 112, i'm surprised anything cools...
