Year: 2004
Make: Ford
Model: Taurus
Engine Size: 6cyl
Refrigerant Type: R134
Ambient Temp: 70
Hi
Can someone tell me what the High and Low pressures should be for this car?
This is all I could find this morning.
Compressor Type Visteon FS-10 swashplate, 5 double-acting pistons Displacement 170 cc (10.4 cu in) Rotation Clockwise
A/C Pressure Relief Valve (1) Open pressures 3,792-4,137 kPa (550-600 psi)
Evaporator Core Orifice Color Orange Diameter 1.45 mm (0.057 in)
Magnetic Clutch
Air gap clearance 0.35-0.75 mm (0.014-0.030 in)
Dual Function Pressure Switch (1)
Fan on/open 2,137-2,344 kPa (310-340 psi)
Fan off/close 1,655-2,137 kPa (240-310 psi)
Clutch off/open 2,999-3,275 kPa (435-475 psi)
Clutch on/close 1,517-1,931 kPa (220-280 psi)
Low Charge Switch
Open pressure 69 kPa (10 psi)
Close pressure 138 kPa (20 psi)
Evaporator Discharge Temperature Sensor
On temperature 4ðC (39ðF)
Off temperature 3ðC (37ðF)
Refrigerant Lubricant and Capacity
PAG Refrigerant Compressor Oil (R-134a Capacity 195 ml (6.6 oz)
Refrigerant and Capacity
R-134a Refrigerant YN-19 WSH-M17B19-A Capacity 0.96 kg (34 oz)
Tim.
Martin
