Year: 1994
Make: Dodge
Model: Ram 350 dodge 15 Pass.
Engine Size: 5.2
Refrigerant Type: r134a
Ambient Temp: 85
Pressure Low: 28
Pressure High: ?
Hey guys ! I have a 1994 Dodge full size van with rear air the rear fan will not run checked fuses all OK is there a relay some were if so do you know were? Hooked gages up but high side coupler would not connect is Dodge different all others have popped right on? Fired it up with low side only hooked at 2000 -2500 rpm low side pulled down to 8 -13 added till low side was 25-28 " Pipe from "H" block was real cold "only cooling to 48 -54 inside at front center vent with max a/c ,fan on high "rear fan will not turn on".
Should I have let it pull down to 18 - 22 ? Did I over charge it? wish I could see the high side reading Any help I would be thankful.
Life is not measured by the number of breaths we take - but by the moments that take our breath away
Thanks, Randy
