Year: 1987
Make: Porsche
Model: 911
Engine Size: 3.2L
Can a system overcharge lead to fuse overheating and blowing? If so why? Controversy on another forum on this issue. I had this problem 2 years ago after topping off my R12 charge. After troubleshooting by cleaning up the fuse block and wire connections did not solve the problem I took the car to the dealership. They said overcharging can create more load on the system and lead to the the electrical overheating issue. My plastic body bullet fuses were overheating and melting vs blowing the metal part of the fuse. Tech evacuated and recharged with the recommended qty of R12 and no further problems - period.
On other forums, it has been argued that there is no way coolant charge will affect electrical performance of the system. If this is not true, what is the technical explanation why?
Thanks!
On a 1970 VW with AC, I also experienced occasional fuse melting v. fuse blowing in an inline fuse. I purchased a new inline fuse holder and moved the 30 amp fuse into an area in the trunk that had a little more ventilation. I was in Arizona, figured underhood heat was one of the reasons.
This is in a Porsche 911 and the fuse panel is in the front trunk away from the engine heat.
Is your compressor driven by the engine or by an electric motor?
Overcharging will not overload any of the electrical parts. The technical explanation is that the clutch coil just generates a magnetic field to pull the clutch plate in. The current does not vary with any mechanical operating condition.
Most likely you're going to have to replace the fuse box. After overheating once, the spring contacts that connect to the fuse have lost their temper. No amount of cleaning up or re-bending them will help. They will never make good contact with the fuse again.
Ding Ding Ding We have a winner!
If the plastic body fuses are melting, the contacts are junk. Your best option is to replace the high current fuses with a new fuse block for real fuses.
I don't know why the square-heads stayed with the crappy fuse design for so long. Original fuse bodies were ceramic, and the clip tension was fairly high. That still did not address the lack of contact area with that fuse design. 20 (or more!) amps through a contact area of about .001mm just makes a heater. Then the plastic "bullet" colapses a little bit, the contact pressure goes down...
Bypass the OEM fuse block for the high current stuff, and use some standard automotive fuseholders.
B.
He is a semi-logical explanation, overcharge causes severe high pressure in the compressor that can cause the clutch to slip. In slipping it generates friction causes red hot heat that can actually burn the enamel insulation of the clutch coil causing a major short circuit. However, this is not reversible by recovering the refrigerant, once the coil is toast, it's toast and has to be replaced along with the rest of the clutch and the idler bearing as well, it's grease is also toast.
Have already seen this. With only minor slipping, the coil will get warm or even hot, and since copper has a positive temperature coefficient, it's resistance will increase decreasing the clutch coil load. That does not blow a fuse.
Queer electrons can also blow fuses.
