Year: 2001
Make: Toyota
Model: Corolla
Engine Size: 1.8
Refrigerant Type: r134a
Ambient Temp: 85
I am going to replace my condenser and drier on Friday. I cannot seem to find out much oil to put back in the system? Also how much refrigerant do I put in?
I tried to search the net but could not locate the answer.
Thank you in advance, this is a great site!
http://napabeltshose.com/news/index.cfm?location_id=1078&id=1517&show=newsitem
21.2 - 24.7oz R143a
4.1oz Oil
High Pressure 199psi-213psi
Low Pressure 21psi-36psi
Both of those pressure's with ambient temperature between 86*- 95* and 1500rpm engine speed.
Thanks for the info!
Okay I installed a new condenser and drier and O-rings.
Everything looks good. I am getting 27F out of my vents at idle. My AC was very cold before thought, so this is normal.
I set the gauges to the following:
Low Pressure: 30 psi
High Pressure: 200 psi
I set these pressures at IDLE though..
Will it hurt anything if I set these pressures at IDLE??
Edited: Sat July 04, 2009 at 1:11 AM by chmura
