Year: 1996
Make: GMC
Model: Suburban K1500
Engine Size: 5.7L
Refrigerant Type: r134a
Ambient Temp: 85
Pressure Low: 30
Pressure High: 205
Strange Pressure readings when running rear air only.
Running both Front and Rear Air:
1500 RPM All Windows Open
Ambient: 85 degrees
Low Side: 30
High Side: 205
Front Vent: 46 Degrees
Rear Vent: 52 Degrees
Running Rear Air only:
Low Side: 70
High Side: 110
Rear Vet: 75+ Degrees
Am I undercharged? What should good pressure readings be? Too much oil?
Edited: Thu July 16, 2009 at 9:06 PM by jjjinu
My guess is when the front fan is off, the front evaporator becomes the coldest part of the system, so it fills up with liquid R-134a and the rest of the system has none. Combine that with the slightly low high side and I'd say it's undercharged. Really the best way is to evacuate and charge by weight, then if it still doesn't work properly you can consider things other than the charge level.
