Year: 2007
Make: ford
Model: 1/2 ton
Engine Size: ?
Refrigerant Type: 134-a
i havent got all the info, the person asked me why his truck's a/c stopped working when the temp outside reached the 90's, it quits for 5 minutes than works again , could this be due to a faulty pressure switch or over charged , your best guess will be fine thank you
jack31ca
jack31ca
check cycling switch, and most likely clutch gap adjustment is needed...When it stops tap on the outer part of the clutch inwards (be careful of turning belts and fan) if it grabs, the gap is to wide...
