Year: 1995
Make: Pontiac
Model: Firebird
Engine Size: 5.7
Ambient Temp: 90
Replaced the accumulator. Had to get a 1994 one because the fittings for the 1995 one were clocked wrong for the hose from the accumulator to condenser. Used the o-ring that came with the accumulator on the hose fitting on the condenser side. It leaked a lot. Found one with a larger cross section and tried it. Leaked a little less. Got a genuine GM one from the dealer. Now it leaks less but still leaks, The hose from the condenser to the accumulator does not look like a 1995 style. It did however seal to the old accumulator. What am I doing wrong that I cannot get it to seal?
I show all driers for 94-97 5.7L Firebirds as being the same. Are your fittings 90* from each other or more around 120*from each other. The 3.8L had a different drier and that is what might have happened. Same threads but the angle may put more stress on the lines while trying to seal.
The one I ended up using has the fittings about 120 degrees apart. The other one would not line up with the hose.
