Year: 2007
Make: Toyota
Model: Corolla
Engine Size: 1.8
Ambient Temp: 80
Pressure Low: 80
Pressure High: 80
Country of Origin: Martinique
I Am Working on a Toyota Corolla with a 6seu16 compressor what is the most common problem with this Compressor ? I see a diagnostic tool on HTTP://CLT1.COM. Has any one use this tool?
If you are having an ambient pressure of 80 then that probably isn't enough to kick on the compressor. What is the reason for working on the compressor? Is the system leaking? How much was evacuated? Does the compressor even engage?
