we have been recharging our own tractor ac systems for the last two summers,along with two of our neighbors. but we have at least two tractors that we need to empty before doing repairs. what would be a good system to preform this work? what is the differance between a recovery machine and a reclaimer?? i guess a good all in one machine that will recover the r134a , test for leaks and then refill the system would be best. we have a vaccuum pump. thanks in advance!!
69100 should work fine for your application. Reclaiming machines do not test for leaks. You need a good electronic leak detector for that.
Tek-Mate
