Year: 1995
Make: Ford
Model: Mustang
Engine Size: 5.0
Ambient Temp: 75
Pressure Low: 30
Pressure High: 100
Sorry for the hodge podge prior post.....
My Mustang does not cool, hooked up gauges and this is what I found. Compresser cycles with the low side going down to 22 then up to 58 the cycles again. All this time my high side does not go above 100. Any ideas? TYVM
What are the pressure's after a fresh vacuum and recharge to proper amount?
When we got the car, I pulled a vac and let it sit overnite with no movement. I the serviced it with 34 oz of 134. Pressures were Low 30 then cycling stopped it rose to 58 and the compresser cycled again, during this time the high side got up to 185/190. It was 75 degrees out. This was approx. 3 weeks ago.
sounds like loss of refrigerant. Check your spring lok connections
