How much better is a parallel flow? Is it worth the upgrade to Parallel from 6mm expanded tube.
Here is where I found the condenser.
http://www.vistaproauto.com/20-condensers?top
Edited: Sun May 23, 2010 at 2:36 AM by Turbo
In my opinion they are a set up from a serpentine condenser. But do not dissipate the heat like a true veined PF condenser. I'm some cases if you want a direct replacement that is the model you may have to use.
