Year: 97
Make: chev
Model: suburban
Engine Size: 5.7
What is the thickness of the electric fans that are sold on this site, and should they be mounted on the outside of the condenser of the on the engine side????
7cm from the base to the back of the motor. As for mounting it. All depends on if you are running it in pusher or puller mode.
I can mount a 10 inch fan on the drivers side of the condenser sincew the right side has an oil cooler mounted to it. I could also mount 2 fans on the back side of the radiator in front of the engine fan. What to do???? thanks ARNE
