Year: 1979
Make: chevy
Model: blazer
Engine Size: 350
just replaced entire system condenser,drier,all hoses,compressor the works.
vacuumed the system no leaks. clutch wont kick in, jumped the cutoff switch still nothing, put pressure on system still nothing.
checked all wiring and power all good.
don't know where else to look .
any suggestions?
Check that the clutch is getting power and ground, measure voltage at coil with everything plugged in. Check that clutch coil is not open circuit (resistance should be approx. 3 ohms). Check that the gap is not too wide.
