Year: 2003
Make: Chev
Model: trailblazer
Engine Size: 4.2
How to ck clutch gap on this-
issue clutch wont stay engaged - 12v at clutch- cools down then engages again
I'm driving one right now-that is having same problem- I wait unti it screws up- then tap on front of clutch- it pops in- that proves air gap is too wide-- I remove a shim and be done.- why check the gap-- meerly remove a shim-- and make sure it doesn't rub when re-installed..that's what I always do.
