If I have the vacuum pump hooked up and running on a car and the power happens to go out, will it suck the vacuum pump oil into the ac system?
no
I'm sure we could devise a scenario in which you might suck some small trace amount of vaccum pump oil into the a/c system. Something along the lines of position the vacuum pump SUPER close to the service port connection via a 6" or shorter hose, and making sure it's slightly ABOVE the service port to ensure gravity helps out. Also make sure the vacuum pump is slightly overfilled with oil to increase the liklihhod of it discharging a small quantity into the hose.
For all PRACTICAL purposes, the risk of sucking vacuum pump oil into the a/c system is pretty much nil, as GM Tech concisely noted. Not sure how you all set things up, but my vacuum pump is on the ground or close to it, and my hoses are at least 4' long. I suspect it'd be a cold day in he$$ before any amount of vacuum pump oil suctions its way into the a/c system as the result of a power outage.
Edited: Mon July 29, 2013 at 2:56 PM by webbch
