Year: 1999
Make: Porsche
Model: Boxster
Adapter source - seal ring block to 5/8, AN12, etc.
Looking for an adapter source - seal ring block to 5/8" or..
Boxster / 996 Condensers have these compressor block type of fittings - need to attach with universal hose connections
http://www.autopartscomponents.com/Content/parts/original/101014_7114_o.jpg
some v8 conversion shops sell peanut adapters, but $40-60 each
other options I suppose include tig welding an a/c/ fitting bung to the aluminum tubing
or even taping through the existing outlets with a 1/2" X 18 threads with a union
Sadly, Doc's Blocks went out of business about 3 years ago.
You say the condensor has a block fitting - what attached to it? got pics of what you are trying to accomplish?
thank you.
trying to attach to the standard 996 / Boxster connection with universal hose connections
That looks like a standard "Peanut" fitting.
TIG welding AN fittings to he mating part works, but you would be better off using refrigeration fittings & hose. AN flare fittings can be a challenge with refrigerant, and you need to use teflon hose. Refrigerant barrier hose & "O" ring seals are better suited to this job.
Tim at AC Kits most likely has the right parts to do this. He has 27 pages of fittings:
AC fittings listings
He still needs to add a lot of pics, so calling him might be faster.
Whole site needs a lot of images added. Once I get my move done I work on a few things. With 12K of items listed now. I may take some time to add them all.
