a.c condenser removal
archie on Mon November 30, 2015 7:55 PM User is offline
Year: 1990
Make: chevy
Model: astro
Engine Size: 4.3l
Refrigerant Type: r134a
hi, I need to know how to remove the a/c condenser on my astro van. can someone who has done this, help. thanks.
GM Tech on Mon November 30, 2015 8:03 PM User is offline
Fairly straight forward- but realize that galvanic corrosion has probably set in- the plated nuts threaded on to the aluminum connections will be suspect. Aluminum and steel do not get along- and the plating to avoid that, doesn't work very often. If you can get the nuts turned off without removing too many threads- then the rest is a piece of cake. remove the grill first.
