Year: 1996
Make: Chev
Model: 1500 Pick Up
Engine Size: 3
Ambient Temp: 75
Pressure Low: 35
Pressure High: 180
Can the cycling switch be replaced without unloading the system on 1996 a Chevy 1500?
Yes, unless someone has removed the scharder valve in the port under the switch. You will loose a small amount of refrigerant when unscrewing it just as you loose a little air with a bicycle pump.
Thank you very much for the info. This system has been a complete pain. I finally observed that while the sytem is on and the compressor running, if I gently push on either side of the cycling switch it shuts the compressor down. I was hoping not to have to evacuate again. Thanks again
It may not be the switch- but the connector to it may not be sueazing the pins tight enough- have seen it before- I use a pick and bend the clamps a little. The switch may be fine.......
Edited: Tue April 13, 2004 at 12:21 PM by GM Tech
