Hyundai XG350 Not Cooling
Posted: Tue May 24, 2016 12:17 pm
My 2005 Hyundai XG350 began to blow warm, not a big deal for an older car in the south. Gauges showed normal low side (40-50PSI) and high side was high (300+ at driving RPM). Figured it was a plugged / bad expansion valve. Replaced it. Added freon. Seemed a little low on both gauges, added a bit more until low side was 45, high side was around 235 at idle (it's hot today), High goes to 275-325 at highway RPM. Seems still too high and output is only 70 degrees at best. Condenser air flow is good, fan operating normally.
Now what?
Now what?
