Year: 1996
Make: Chevrolet
Model: Cavalier
Engine Size: 2.2L
My 1996 Cavalier's V5 compressor has a bad shaft seal. Is the shaft seal something that is practical for the home mechanic to replace? I have plenty of mechanical aptitude as I restore old cars for a hobby, but I don't have any of the special tools needed to work on the compressor. I have done A/C work before, but it was pretty much remove and replace. If the shaft seal needs replacement it seems like a waste to replace the whole compressor. I would be willing to invest in the tools as long as they aren't too expensive. Does the Mastercool 91269 tool set have ALL of the tools needed to do this job? The compressor tool chart I saw linked from this site (somewhere) showed some tools from the 91270 DA6 tool set that might be needed. Does the clutch, etc. come apart fairly easily?
Also, is there any shaft prep work recommended?
Edited: Sat August 19, 2006 at 1:51 PM by Mach5
I have no leass then about 10 ten tools I use- several of them are home made-- I do those shaft seals on J-cars (Cavalier) without removing rhe compressor from the engine- did a '96 and a 2000 this week. The clurch puller/installer is essential- I then use an awl to yank out the snap ring- then a shaft seal puller tool to get the shaft seal out- then a dental pick to pull out the o-ring- then I clean the interior with alcohol wipes- then I install the new o-ring- then I put the shaft seal protector tool over the shaft threads, then I use the same shaftseal puler tool to mount and twist the new seal into place- after oiling the teflon and o-ring surfaces- then I use snap ring pliers to put the new snap ring in- then I use the clutch installer to re-install the clutch to .020" and then put the plasric panel back- evacuate- add dye/oil mix and recharge to spec- takes about a half an hour total= once you've done a hundred or so............good luck and you're right- it is much cheaper than a new compressor..........
What brand of clutch puller/installer, etc. do you use? Kent-Moore? Mastercool? I wanted to get the tools squared away first...I hate getting halfway through a job and finding out I need a special tool that will take 3 days to get shipped to me.
Thanks for the reply.
if you get Kent Moore, there goes the kids collage fund... But I use mastercool clutch and seal tools...1/10 the price of kent moore "J" tools..
Mastercool clutch plate remover #91212
Installer#91260 and washer/bearing #90458 for installer
91212 remover is shown as being for a metric thread, while 90458 installer is for a coarse thread. I'm guessing the V5 has metric threads...so I should use the 91213 installer, right? What seal remover & seal protector is needed? Thanks again.
The installer uses basically the same threads on most of GM since it screws on the shaft that the nut was on. The clutch plate comes metric, which is what you need, and usually the older A6 and R4 compressors use the course threads. I'll have to find the numbers for the seal remover and shaft seal protector later.. But use the numbers I gave you for your compressor. I know it works, I do them a couple times a week now...
PS: If you're not going to buy them, you can usually rent the hub remover/installer tools from autozone. They won't have the seal remover though..
Edited: Sun August 20, 2006 at 8:27 AM by Chick
Shaft seal remover. Mastercool number 90486
Shaft seal protector number 91211 or 90484
Here's a pic of the O ring, Snap ring, felt washer (not needed) shaft seal protector, shaft seal, and seal remover/installer..You can get all the parts you need from Ackits.com..Hope this helps...
