Year: 1990
Make: ford
Model: f-150
Engine Size: 302
Will a hose assambly from a 1995 ford f-150 fit a 1990 ford f-150 dryer?I am changing my condensor in my 1990 to a 1995 because i`m switching to 134a and my old one is shot anyway,so will this work
I think you will also need the liquid line from the condensor to the bottom of the evaporator where the O-tube is.
The liquid line has the same fittings as the 1990 comdensor but the highside of the 1995 condensor has a larger fitting then the 1990 one so the 1995 hose assembly will bolt to the 1990 dryer?I know the 1990 and 1995 have the same compressor.
anyone help with this question?
Thanks chick,I am only worried about the connection between the dryer and the hose assembly?
I have a new dryer for a 1990 and needed a new condenson so being I am changing over to 134a I was told to change the condensor to one that is made to work with 134a. and that a 1990 condensor won`t work to good with 134a.
