Year: 1998
Make: Toyota
Model: Sienna
I have a general question on charging a system.
If a system calls for 26 oz. of R134A, do I need to overcharge some amount to account for the loss of refrigerant that is trapped/lost in the hoses when they are disconnected? I have read that as much as 4 oz. of refrigerant can be in the hoses.
A couple ounces extra for what is left in the hoses..If using a scale, let the lines fill before zeroing the scale... You have to "judge" if not using a scale, so an ounce either way is no big deal, just make sure the suction line going back to the compressor is cold when you think you have the full charge in..You can't feel the inlet and outlet with the expansion valve system you car uses....
After charging, disconnect the high side hose from the car, close the valve on the R134a source, then with the compressor running, (double check high side hose is dosconnected) slowly open both valves on the manifold. Both gauges should read the low side pressure. This procedure pulls any liquid refrigerant out of the gauges and hoses, the amount remaining now is truly negligible.
I think that procedure would depend on the type of hoses you have, mine do not have schrader valves to close off atmospheric air, my hoses have inserts that push on the schrader valve on the car LO and HI ports but bleed off the hoses to atmosphere when disconnected from the car.
Give all the dirty details
and dont forget the LO & HI pressures
Year, Make & Model would be nice too
Old R12 sets were like that. A standard R134a set will have isolation valves in the car couplers and on the yellow hose. The law in the USA requires isolation provisions, so anything sold here of modern manufacture (other than maybe the really cheap Chinese stuff) will be built that way.
Thanks for clearifying, I have both just as you stated, thanks to the member who gave the evacuation of both hoses procedure, after years of doing this its the first time I have heard of the procedure, so the hoses will be drained of their liquid freon and be drained down to about 30 PSI (running LO side pressure) of gaseous freon leaving less waste, thanks.
