Year: 1995
Make: Dodge
Model: Neon
Engine Size: 2.0L
Ambient Temp: 75
Pressure Low: 25
Pressure High: 200
What type of oil should be used in my 1995 dodge neon. How much oil should be added if I'm only changing the compressor. How much if the system is empty?
THanks for the help
PAG46
Drain compressor add back that amount drained plus 1.5 ounces.
Edited: Mon November 26, 2007 at 2:46 PM by ice-n-tropics
