Year: 01-02
Make:
I have probably seen 40 or 50 Mitsubishi system OEM condensers (Pontiac Montana, Olds Silhouette, Chevy Venture, also Buick Rendezvous and Pontiac Aztek) that leak at the bottom right hand corner (passenger side)- Last week I got a 2002 Chevy Venture - friend of a friend- that they swore the condenser was replaced 3 yrs ago- I told them that if so - there are tell tale signs that I will watch for- such as bolts missing, and most importantly-- the replacement condenser has a "blank" tab at the mounting location where the leak occurs-- (obvious stress point)- Every replacement condeneser I have ever bought (approx 20) - regardless of manufacturer- has always had the mounting tab blank (no hole). This condenser had the hole and it was mounted just like OEM.
The owner called the shop that "replaced" the condenser 3 yrs ago- they pulled up her records- they say yes, they replaced the condenser- bought it from the local GM dealer- and charged her $900.
I'm here to say BS- that condenser is OEM- it even appears to have a label with a date code that if read right- is actually 4 wks before the build of the vehicle-- which further proves it is the original.
Plus I have NEVER seen a replacement condenser fail in the same place as the OEM---
And absolutey every bolt and wiring harness tab etc was in place- exactly as it left the factory- there were no shortcuts found (as usual when I follow another mechanic).
So since so much time has elasped, I doubt anything can be done-- they did have a loss of a/c 3 yrs ago-- perhaps the "shop" took advantage of the "well known" condenser problem and made another repair (the actual problem) and charged them for a condenser replacement. I'm really bothered by this, my main question is to this forum is -- Has anyone ever seen a replacement condneser that has the hole in the mounting tab? Even when I bought from GM service parts- the condensers NEVER had the hole. So what are your opinions? Did she get taken????
This is the aftermarket model we offer.
Thanks Tim- I see the hole is there on yours-- it is the first time I have seen it -- But your photo is upsidedown as installed- but I suppose the marketing gurus don't know the difference- I saw one on another site that is also displayed upsidedown- and it clearly shows no mounting hole
I plan on keeping this condenser until I get the next one (won't be long) that I know has never been changed- then I can take measurements etc- to prove to myself that it is an OEM unit.....
The saga continues.....
Edited: Thu May 08, 2008 at 12:44 PM by GM Tech
Better?
