Year: 1977
Make: Chevy
Model: Truck
Engine Size: 350
First two times I used the double lipped rubber seal with no luck. Today I put in the old style two piece seal. I hope it works, but I have my doubts. After charging it, there were little oil smears on the fender well and on the ac hose. I'm going to keep it wiped up and see if there is less oil after each use. I ran the leak detector around the clutch and didn't go off.
The vent temp was getting down to a frosty 35 degrees before it would cycle.
Good luck let us know how it comes out.
