Year: 1996
Make: Ford
Model: F350
I want to purchase the inline filter from AMA but I cannot find directions on how to choose one and how to install (where and how). Can someone tell me how and where to install? The PDF directions link on the AMA website does not work.
Works now.
Tim- If I were you- I'd recommend inline filters to customers who may not have thought of this..... for any nasty 3/8 liquid line corrosion or rub-through failures-- I use the filters just to splice the lines- after I cut out the bad spot-- I've save mega bucks and time by doing this- who wants to replace the 12 ft liquid line on a full sized van (rear air) when you can splice in a filter..... the instructions clearly say to cut out a 2 inch or so section of line-- I just choose to cut out the bad area.....pretty good huh!!!
After doing that for awhile- I soon discovered the swageloks- which work great as well-- but your filter would serve a dual purpose in this role
So my current orifice will fit into the filter? Also, I'm not good at guessing tubing size, how can I tel the size of my line? It's a 1996 Ford F350 pickup with the diesel engine.
This filter fits all 3 standard lines.
Universal In-line Filters OEM APPROVED
Universal High Side In-Line Filter
OEM Tested and Approved
Protect Against Costly Repeat Compressor Failure
Single Kit Fits 5/16âÂÂ, 3/8âÂÂ, and 1/2â Lines
Captures Residual Debris in the A/C System
Can be Used as a Line Splice or Repair Device for
Damaged Orifice Tube Holders
Incorporates any size orifice tube with Included
Installation Clip
Quick and Easy leak free installation
Requires only 4â of straight refrigerant line
Tapered sealing sleeve provides 10 times the sealing area of older filter designs
Shorter overall filter length, with 3 times the capacity of older filter designs â reduces pressure and flow restrictions
Provides the reliable solution technicians have been asking for to reduce comebacks on compressor replacements -- especially rear A/C Systems
13128TSI
