Year: 2007
Make: Eclipse
Model: 500
Engine Size: 2 jets
Refrigerant Type: 134
Hey guys,
I'm at work right now (Eclipse Aviation). The aircraft uses a standard AC system very similar to a car. The problem that I am having is that the front AC vent temps warm up about 10 degrees with the rear ac turned on. Does this point to just servicing or could it be something else?
Travis
1993.5 Single Turbo Toyota Supra 714RWHP
1985 Suburban
1997 Pontiac Grand Prix GTP
TXV system right? Does the rear have a solenoid on it? Possibly low on charge. Pull the charge and put the proper amount in it. This will eliminate refrigerant charge as a problem.
