Year: 2000
Make: dodge
Model: grand caravan es
Engine Size: 3.3
Ambient Temp: 90
Pressure Low: 38
Pressure High: 275
Could someone direct me in the best way to access the cabin air filter?The book did not mention one but parts house has a listing for one .I did look behind and under the glove box but not real sure.Under the hood on firewall side looks like wiper arms may need to come off to access thru fire wall. Thanks for any replies.
Locate the air filter door on the bottom of the lower evaporator housing just outboard of the
passenger side of the instrument panel center stack.
Slide the air filter door latch toward the rear of the vehicle until it engages the opened stop on the
door.
Pull the air filter door latch straight downward to disengage it from the air filter opening of the
lower evaporator housing.
Use your fingers to reach through the air filter opening of the lower evaporator housing far enough
to grasp the air filter.
Pull the air filter straight down and out of the evaporator housing.
