Year: 1993
Make: Dodge Truck
Model: D-250
Engine Size: 5.9L Die
Refrigerant Type: R-12
Ambient Temp: 80.00
Hey all,
I charged and flushed this system about 1 1/2 years ago and the AC was working like a champ, nice cold air all the time. However, the other day I was at a stop light, the motor was at idle and then the High Pressure Relief Valve opened to let some of my expensive R-12 out. It didn't a few times and now I can see lots of bubbles in the accumulator window and the air is now warm.
Here is my question, what would cause this to happen? What is the high fail item? I am thinking about replacing the High Pressure Valve and the expansion block.
Any comments or questions will be greatly appreciated.
Thanks in Advance
Brad
I suspect the condenser overheated because the fan clutch is about dead. You could add a HPCO switch if the system doesn't already have one.
At idle at a stop is the key-- condenser needs airflow- yours is lacking-- new clutch fan is needed or an operating electric auxilliary fan.
I agree. Clean the bugs out of the condensor while you got the hood open.
Dang,
I replaced the clutch/fan about 2 years ago, what are some tips to make sure I need to replace it? How can you tell its bad, my motor water temp is normal.
Was it a OEM fan clutch or a parts store knockoff? Recover, evacuate, and recharge to the specified weight of R-12. If the high side is too high, about the only thing that can cause that is inadequate condenser cooling. Usually the A/C performance will suffer long before the engine starts to overheat.
With it running see if it's spinning fast enough to move any air. If you let it run at a fast idle with the radiator mostly covered it will get pretty warm the fan clutch should hook up and roar
Purchased the clutch/fan from NAPA..so it could be bad..
What I did was charge the system with enough R-12 to make the bubbles go away in the accumulator window.
The high side went to 155 with the amb temp approx 78 with about 40% humidly
The system worked like it did before the high pressure valve opened up, I let the system work at idle for 30 minutes with no problems.
The fan is moving air because I can fell the air being drawn in from the front of the truck.
Could it be possible the a plastic bag or something was blocking the air and feel off before I got home?
At what pressure does the high pressure relief valve open?
