My refrigerant identifier came in the mail today so I ran like a little kid into the garage to test the refrigerant in my e-bay special 30lb R12 cylinder and the recovered refrigerant from my '85 Mercury Cougar (now receiving an engine/tranny from an '02 Mustang V6). The results from the e-bay special was 100% R12. Yah! The Cougar came back as 97.3% R134a and 2.7% R12. Not expected since it was an R12 system (or at least I thought it was).
Looking back at my receipts, I'm somewhat surprised it never died.
July '96 - Received car. A/C worked fine.
A/C eventually gives out over the next two summers
July '98 - Gets A/C recharged (presumably, w/R12 since no conversion fittings were put on) while in the shop at a shadetree mechanic for other work
A/C eventually gives out during the next summer
July '99 - Get A/C serviced. Informed current charge is ~70/30 R134a/R12. Schrader valves, springlock o-rings, and cycling switch are replaced. 2oz of oil added. R12 charged back. Tech tells me it's been a long time since he's seen an HR980 and he doesn't think he'll see me again (inferring compressor won't last).
December '04 - Get A/C serviced due to short-cycling and oil leak on condenser springlocks. Tell the tech system is still R12. Tech recovers 1lb 8oz, replaces condenser springlocks and adds in 2lb 12oz of "R12".
August '08 - Recover refrigerant for engine swap. 97.3% R134a 2.7% R12.
Sometimes it seems like it's too much to ask for a shop that does decent A/C work. Oh well. I like my new toy and have all the A/C goodies except for a hose crimper.
Edited: Thu August 28, 2008 at 11:16 PM by JeremyB
People ask us all the time why the first thing we do is test the refrigerant for purity and sealer!
Just posted the invoice for this stuff, thanks for the support!
Bad news is that the guy in '04 sold you 134a saying it was 12. Good news is you now know your car works acceptably well with R-134a. If you use the compressor from the '02 Mustang it's going to have PAG in it, which means you should refill the system only with pure R-134a, not the mixture you recovered.
I am planning on running R12 with a new/rebuilt Mustang compressor (FS10) and using POE oil for the system. Any problems with that?
Went and replaced a compressor on a friend's '92 Sable. Presumably an R12 system w/o any conversion fittings. 98.8% R-134a.
I'm not a fan of remans with the FS10! Go new if you can as they are fairly cheap.
The 92 uses an FX15, and I would not use R134a in that, change it to a "new" FS 10. The FX15 is a black death compressor, probably the worse of all of them... Hope this helps..
I recommended a firewall forward fix. He only replaced the compressor with a reman'd Murray FS10. I got ~10oz of R134a in before the high side went over 325 psi. I shut it down and told him a firewall forward replacement was the only way to go.
