I just removed a springlock fitting between the evap core and the accumulator using my quick disconnect tool marked 3/4". But, for some reason, when I look at the specs for the inlet and outlet for this same accumulator on Autozone.com and it says 5/8"! What gives? Are the fittings rated by the inner diameter of the female fitting and the tools rated at the outer diameter?
Edited: Wed May 20, 2009 at 1:31 PM by booksix
Anyone?
Open the fitting PDF in this link. There are basically just a few size fittings with different connections.
http://www.ackits.com/additional/main.htm
Thanks, only problem is the pdf won't load properly. Shows up as a gray window in the browser and when I download the pdf and open it I get an error saying it cannot recognize the file... ?
Works for me.
http://www.ackits.com/additional/Fittings.pdf
I should have been more clear; Its Ford.pdf that doesn't work...
