Year: 96
Make: Ford
Model: Explorer
Engine Size: 4.0
Ambient Temp: 77
Pressure Low: 30
Pressure High: 160
My a/c compressor runs constantly now that I put in the total amount of 134a (26oz)....maybe there's just a bit more (I have no way of measuring the amount put in but I know it's over 24oz. (by way of back ground- I R&R the compressor, dryer, orifice and flushed the system yesterday).
Yesterday, when there was about 24oz in, with an ambient temperature of 65, the compressor cycled off and on every 8 secs. or so. Pressures were, I think, 145/25.
Should I expect the compressor to be running constantly now?
If not.....how can I fix it?
Thanks.
The warmer it is, the less it will cycle.. Is it cooling? check the pressures wehen it's 80+ degrees Hope this helps..
It doesn't cycle off at all.
The ambient temperature is now about 80. Low humidity....if that matters.
Yes, it's cooling well. But, my hand isn't freezing in front of the vents. I haven't measured the vent temperature yet but it's cool (but not freeze-you-to-the-bone). By "cool" I mean that if it was 90 out.....I'd be a little concerned that the a/c might not keep me comfortable enough. That's just my opinion about the vent temperature.
As I said, yesterday it was cycling off and on quite nicely about every 8 to 10 seconds with an outside temperature of around 65 (I think that's what it was) There really was just a little less 134a than 24ozs. My system calls for 1Lb 14oz (which I interpret as 30oz).
Hope that helps explain my situation a little more.
Thanks for the help.
Raise the engine RPM to above 1500 with the cabin fan on low. It should cycle occasionally.
Cycling is an indication of either undercharge, or excess cooling capacity. Systems may not cycle depending on load & condition.
Do a full load test. Doors open, cabin fan on highest speed. Run the engine above 1500 RPM for 5 minutes, and record the high & low side pressures while the engine is still running above 1500. Post the results.
B.
To start with, you need to have the correct amount in the system, if you are low, add more til you have the correct amount. You can damage the compressor running it low... Also, feel the inlet and outlet of the evaporator, should be the same temp, with the outlet (suction side) a little colder.. If that is warmer, you are undercharged.. Hope this helps..
Alright, here are the latest readings, do they appear to be good?
1rst situation......
Ambient temperature- 72
Center dashboard vent temperature- between 39 and 41
Windows all open
A/C switch on MAX AC
Vent fan speed- on the 2nd dot (that is- low speed)
Pressures- 175/20 (compressor off)
80/45 (compressor on)
2nd Situation.......
Engine RPM- 1500
Vent fan speed- full speed
Center dashboard vent temperature- between 41 and 42
Windows all closed
Pressures- 175/25 (compressor off)
3rd situation-
Same as in "2nd situation" except A/C switch on AC (not MAX AC) and......
Pressures- 200/30 (compressor off)....I pretty sure of the Low side number. Seems strange doesn't it?
Thanks fellas.
Edited: Wed May 20, 2009 at 7:46 PM by PDA1
