Year: 1981
Make: Buick
Model: Regal Sports Coupe
Engine Size: 3.8
My shaft seal kit for my R4 compressor finally arrived, (21-34734). It came with a snap ring, O-ring gasket, shaft seal and a weird white cloth type gasket.
Where does this thing go? Everything else is good to go but I've never seen this cloth thingy. Is it some type of oil lubricant retainer for the bearing?
DIY'er for life!!
Felt strip, its slides in before you put the hub back on. It is GM's way to help control oil sling!
So I first install the felt gasket into the hub, then I install the o-ring, shaft seal and finish with the retainer?
Should I drench the felt gasket with PAG-150? Or should I leave it dry?
DIY'er for life!!
The felt washer goes in after the seal, leave it dry, or you can even leave it out. Don't see many with them in anymore, but it's there to absorb oil as it comes out of leaking seals.. Kinda makes it harder to spot them leaking...
We always called it a diaper....
