Year: 1997
Make: Chevy
Model: G1500 Express
Engine Size: 5.7
Ambient Temp: 90
Pressure Low: 55
Pressure High: 200
there is some cooling at idle but not great at 1500 rpm it gets better but not much low side is 55 and high is 200 at 1500 low is at 50 and high is 275 i replaced the compressor this past fall, ever since then cooling has been on the poor side at best. I think I have a bum compressor, but the guy I bought it from does not think so.
For help, post answers to all questions.
(1) Is the cooling substantially better when you are driving on the highway at like 55 mph? If so, it sure sounds like you need a new fan clutch for your truck, not getting enough air flow over condenser at low speeds/idle.
(2) If answer to (1) is "NO", how much R134a did you add after you replaced the compressor? When you replaced the compressor, you did pull a good vacuum vacuum with a vacuum pump, didn't you? I ask because both high and low pressures seem a little high, but that can relate to question 1.
Edited: Sun June 21, 2009 at 2:56 AM by Cussboy
cooling is better at 55, yes i pull a good vacuum with a pump put in 5.25 pounds 134a
Read pressures again while spraying the condenser with water from a hose, should go lower, should help cooling. Sounds like you could be needing new fan clutch. At 55 you have increased the air flow over the condenser, need the fan do do a better job of this, hence fan clutch.
what about the orfice tube, could that be clog?
ok i sprayed the condenser with water it did not do much drop low side by 5 lb high side maybe 20 lb. Pressures before i sprayed with water was low side 45 high side 145 at idle at 1500 rpm it was 35 low 160 high. vent temp is at 60 outside is 88. my old compressor had vent temps at high 30's low 40's before it lock up i did change the orfice tube and the dryer when i put in the new compressor
Does this G van have rear A/C?
You said the compressor locked up. How much trash was in the orifice tube?
If the compressor spit out a lot of debris, that condensor is a doorstop. Those have tiny passages, and are very difficult to flush.
B.
orfice tube had some alum. on the screen i did flush the system everything seem to be open . if the condenser was clog up then would my high side be high ? and yes i have rear A/C and that is not cooling very well
yes i flush the rear ac, if my fan clutch was bad would that not cause the engine to run hot i am running at normal temps
what should i see my low and high side be at. the temp is at 90 with 80% humidity
Good low is 27-35, high should be 2-2.5x ambient so 180-225.
i have 60 Low 195 High
my low side is 60 and my high side is 165 at idle, at about 1500 rpm low is 50 high 225 cooling is poor i think my compressor is bad but have been told by the part store were a got the compressor that the orfice tube is bad i have replaced that 2 times now and ac is the same poor
Ask the parts guy how long he has been "fixing" ac systems, rather than selling parts.. O tube has nothing to do with your problem, clogged would show low side pressures..
Could you please explain your flushing procedure? I'm concerned you left some flushing agent behind along with a few issues the others have mentioned.
I used some flushing solvent with a flushing canister i blew the solvent thru the lines and everything till everything look clean than a blew air at low pressure till the solvent was gone
1) Aluminum shards on the orifice tube screen. A good chance most of the debris stayed in the condensor. Pull the orfice & check the screen again. If you find more metal the condensor is full of it.
2) "Flushed" rear system - it sounds like it was flushed through the long lines, TXV, evaporator, lines - all still assembled?
3) Remanufactured compressor or new?
The best answer at this point is a return to square one. Break the system down into individual parts, and flush to bare metal. This means pulling the rear evaporator & removing the TXV. Replace the condensor. New accumulator. Personally I would replace the TXV & compressor with new units. Tim has a nice replacment for that compressor. Do it right, do it once.
B.
Edited: Tue June 23, 2009 at 12:29 AM by bohica2xo
my low side is 60 and high side 170 vent temp 60 i have poor cooling. low side is high but can not figure out why the guy i got the new compressor from first said orfice tube now tells me that condenser is restricted i can't see how with a high side of 170. should my high side be a lot higher if that was true i still think my compressor is on the way out
