Year: 1999
Make: GMC
Model: K3500
Engine Size: 6.5 TD
Refrigerant Type: R-134
Ambient Temp: 90
Pressure Low: 65
Pressure High: 225
So, I buys a new condenser and radiator, and put 'em in Saturday. Changed the condenser cuz old one was mangled by bugs and I got a killer deal on it. Today I goes out and evacuate the system for 45 minutes, held for 15 minutes, ran in a half pound of 134 from a 30lb cylinder and sniffed the two joints I opened for leaks (new O-rings with Nylog, of course). All was well so I ran in 134 from my tank until it wouldn't take more. Started truck and tried to run in more but it would only take a total of 1.5 lbs out of 2. The low side just wouldn't suck down lower than 60-65, even at 1500-2000 rpm. Yes, the clutch was engaged.
I pulled Mom's 97 Odyssey up and it charged right up, pulling down to
Methinks I need a new compressor. Tim was so good to me with my Suburban disaster, I thought I'd see about getting more stuff from him, even though I could get it locally and be done by tomorrow.
Or might it be something else? The radiator and condenser are brand-new -- zero miles. The fan is brand new Duramax composite 9-blade with heavy duty clutch, also brand new with a few hundred miles. Oil cooler is also nearly new, 2000 miles and clean. Trans cooler is also clean. Shroud is in place, I feel excellent "suction" at the condenser; I bet it'd suck an 8x10 sheet of paper up tight.
So, Tim -- I think I need a compressor, a drier, a set of GM O-rings and a pair of new spring valves for the service ports. I have about 7oz of PAG 150 left from when I put the condenser in Saturday. What else should I get? Which compressor should I get? How's the Sanden compare to the other new one you sell (Delphi?)? I want a new one, not a rebuild. I want one that will last; I want one that will cool my crew cab. There's a Delphi on there now. AC worked, but I've never driven the truck when the temp was over 90. The AC did seem a little weak -- no funny noises. 138,000 miles on the truck; I presume the compressor is original.
almost forgot. My Yellow Jacket 134 gauges seem to need new O-rings in the quick connects. I stuck in a small one I had in an Autozone kit, but are there particular ones I should use?
Doug
Home of the "Tunex Suburban Disaster"
Edited: Wed June 24, 2009 at 11:21 PM by mitchedo
Hit me with an email on this and I'll check into things for you in the morning. We appreciate the opportunity to help with your a/c requirements.
Replied to your email. Bottom line in my opinion go with the Sanden.
I am an idiot.
When Tim mentioned that there were two different orifice tubes depending on whether it was condenser or evaporator mounted, I got to thinking I did a stupid thing. When I was putting the engine in, I recalled wondering why they had insulated the liquid line between the condenser and the firewall. I never could see where it went into the firewall (behind too much junk), and I was in a hurry.
Bottom line. The O-tube was sitting in the old condenser leaning up against the garage wall. I bopped down to Autozone and purchased one of those fancy variable O-tubes to give it a try. I think I probably should have taken the time to replace the compressor anyway. The old O-tube had quite a bit of black flecks stuck on it. ...but I wanted to drive the truck to Dad's cabin this weekend, so I just slapped it back together. It works much better with an orifice tube.
I am an idiot.
Doug
Mitch - you're not an idiot - these systems are all different. Think of what you (and us) have learned from this. Glad it's working better.
Doug no worries, I bumped the CPU fan wire plug while swapping out a DVD burner yesterday. No big deal except this CPU is in a tight spot to attached all the cables and plugs so I was saying the same thing when I was pulling out the CPU for a second time yesterday.
While I would still like to sell you that Sanden! Thanks for send a few dollars in support anyway! It is appreciated and helps to keep the forum alive for the future.
You are only an idiot if you do not learn from the best teacher there is... our own mistakes.
I can learn from Chick's mistakes too...
In that case I can teach a lot....
