Year: 1999
Make: Buick
Model: Regal LS
Engine Size: 3800
Refrigerant Type: r-134a
Hi
I have a Santech 2.5 cfm vacuum pump. It calls for HFV-32 oil which I cannot find locally nor so far, on the net.
Is their a substitute oil?
1999 Regal LS
ZZP 2.5" DP, Ubend Delete
GTP duals
12" Brake upgrade
GMPP Handling Pkg
I use Mobil Vac Pump oil, which I found at my local WW Grainger
At 2, I went home with a 10. At 10 I woke up with a 2 !!
I've used about every vac pump oil out there in my J/P 7cfm 2 stage pump, currently using Robinair vac oil in it. I think as long as it's vac pump specific oil your ok.
