Year: 97
Make: ford
Model: ranger
Refrigerant Type: 134
Tim/AMA I need the High side service port for 97 ranger. Do you have the part number? Thanks!
I believe this is what you need. I also believe I out right now but have them on order. I'll double check in the morning after a early doc appointment.
35-50021
Tim the link didn't work. The high side port unscrews it can be replaced correct? Thanks!
Sorry, I fixed it.
Thanks Tim the link worked. This will work to replace the OE valve that leaks. I noticed it said GM.
Tim: The valve in the link isn't the same. The one I have is about 1.25 inchs long & screws on not in. 97 ranger High side. Thanks!
The first one Tim told you about 35-50021 is the correct one for the Hi-side port. This is a GM primary valve that fits GM, Ford and Chrysler. The second one 35-50033 is for the Low side that will fit GM and Ford.
