Year: 1999
Make: chevy
Model: tracker
Engine Size: 1.6
Refrigerant Type: r134
Ambient Temp: 98
Pressure Low: 8
Pressure High: 200
Well took it to a pro 30 yrs He said must have a plug between condenser & txv valve or valve plugged. Took it apart valve looks like new super clean blew through it.
took line from condenser to valve off blew through it ,clear.Took line from compressor to condenser off blew through it ,clear. Back together ,vacuum down,yup
still 8lb low side 200 high side ,16 oz freon,98 degrees ambient,75 degrees vent temp. What else can I do?
what about the drier?? or clogged evap??
If the high pressure port is before the condenser, could also have a clogged condenser. The line might get cold right after the blocked part.
